building a high pass , low pass pedal for 12 string bass.
Started by jschwalls, January 16, 2008, 01:26:17 AM
jschwalls
 Ok, I have no clue as to what i'm doing but i need to build a box that will cut off the highs and lows from my bass.
I play a Hamer 12 string bass guitar and i want to eliminate the extreme lows and highs from going to my guitar amp.
I use a bass rig and a guitar rig when i play the 12 string bass. This pedal will go right before my guitar amp inline.
As you can tell by the prehistoric design at the bottom, I'm a newbie :)
But will this design work .. I realize i may have to "play" with the frequencies after it is finished..
Thanks guys.
IN +..........[ 1uf ].................[15ohms]..............+ OUT
IN - \                           l                                 / - OUT
       l                          l                                 l
       l                        [1k]                           [1uf]
       l                          l                                 l
       l                          l                                 l
       .................................................................[Ground]
  filtering signal between 159hz and 10.6Khz...
JON
btw.. a nicer design would be much appreciated.
dirk
Wow a 12 string bass, that has to be a monster sound coming out of that thing. Every string has 2 octave strings with it I presume?
Here you have an on line RC calculator:
http://www.muzique.com/schem/filter.htm
jschwalls
#2
Quote from: dirk on January 16, 2008, 03:47:12 AM
Yeah, Incredible sound live, but i removed the normal crossover i use from my rack so now i need to build this box to filter frequencies from blasting my guitar amp...
Thanks for the calculator...
I used this calculator, with a sine wave analyzer. Cool Site.
http://www.st-andrews.ac.uk/~www_pa/Scots_Guide/experiment/lowpass/lpf.html
