Is this a gain pot problem?
Started by jimosity, January 20, 2008, 09:54:30 AM
jimosity
I built either the DOD 250+ or Distortion+ a while back, can't remember which one it is - but either way; here's the problem that I have with it that should be a pretty easy diagnosis for someone with some knowledge...
It's basically got a volume and gain control, the volume works fine, but the gain control does nothing unless it's at 100% - that's when the effect engages and there's no actual gradual gain.  When the gain knob is maxed, the effect comes on, at full gain...back off the gain a tad bit and the gain is totally off.
Is this simply a wrong gain pot or could it be a problem with the circuit?
Jim Rodgers
jim@americanhc.com
  Sounds like it...
  reversing the outside lugs may help.
  Using whatever reverio taper pot for the gain knob [specail taper IIRC]...
  Or simply forgo the lower gain settings and use a 100k pot [mine has 22k pot], which spreads out the higher gain adjustability over a large pot range [pointer on knob can actually be used then], but loses the lower gain settings.
