EA tremolo with tube instead of jfet ?
Started by Krinor, January 23, 2008, 02:38:26 PM
Krinor
I was thinking about this nice and simple preamp section of the EA tremolo and a thought struck me: Wouldn't it be nice to put a simple tube preamp in there instead ? How about this one:
http://www.diystompboxes.com/smfforum/index.php?topic=63479.0
And by putting another switch in there I could cut the tremolo section and use it as a booster only.
Your thoughts gentlemen ?
snoof
as long as you don't use the starved plate tube for distortion it should sound alright.  I've never cared much for the low voltages preamp tube disto myself.
The Tone God
Krinor
#3
That is a very nice project Andrew. I was aware of it's existence, but I was thinking that maybe I'd get away with something even simpler. Thus the EA approach.
The Tone God
Which part do you find complex ? Perhaps you can modify or use some of the ideas to build what you want.
Andrew
Krinor
It's not that it is too complex, or well maybe it is. I think I'd leave out the tonestack to keep wiring and parts count down a little. Maybe I'd use a simpler treble bleed only.
The Tone God
That certainly is an option but you will probably have to reset the gain structure of those stages as the gain has been set to recover the loss from the tone stack.
Andrew
