analog delay Johnson EAD 2 humming when fed from wall-wart
Started by yeeshkul, February 05, 2008, 04:28:35 AM
yeeshkul
My fried has a problem with this Chinese analog delay Johnson EAD 2. When it runs on battery everything is all right. When he uses wall-wart there is a lot of hum (which is also changes in dependence on the MIX pot). Can there be a ground-loop through the common ground with his amp? The wall-wart apparently works fine wit the other stompboxes.
Rodgre
It could be that this delay is more sensitive to noise and ripple from the adapter than other pedals. There shouldn't be a ground loop issue if the adapter is ungrounded (no ground lug where it plugs into the AC line). If the adapter isn't putting out a clean, regulated DC voltage, like a lot of cheaper adapters suitable for non-audio power are, then that's the culprit.
Roger
zombiwoof
A non-regulated adapter is just what I was also thinking.  If you're friend doesn't have a good one to try, have him get a Dano like the one in this link:
http://www.musiciansfriend.com/product/Danelectro-DA1-Power-Supply?sku=151851
I assume that the Johnson pedal requires a common center negative adapter like this one, but he should make sure before purchasing it.  I've seen it for as low as $8 at other places, I've got one and it works great.
Also read the customer review on the link page, sounds like others had the same problem as your friend!
Al
