1n5239 substitute for amz mosfet boost?
Started by nag hammadi, February 01, 2008, 10:20:25 PM
nag hammadi
does anyone know of a sub for the 1n5239?  i have a bunch of other diodes....
can they  be combined to get other values like resistors can?
in the face of you all i stand defiant - subhumans
PerroGrande
Any 9.1v Zener with .5W or better dissipation should do the trick.
1N960B
BZX85C9V1
BZX55C9V1
1N757A
1N4739A
Also -- the mosfet boost will operate without the diode.  It is just there to protect the mosfet.
Sack Puppet
You can put many things in there to protect the mosfet.
I have a shipload of 5.1V zeners and usually put two in a similar circuit back-to-back.
I have seen a schematic for a certain pedal which uses 1N4148s between gate and rail then gate and gound - not the best circuit design mind as it had the zener too.
S.
snoof
