[eagle] Closed mono jack library?
Started by Auke Haarsma, February 11, 2008, 10:41:04 AM
Auke Haarsma
Does anyone have a lib file for these mono (and stereo) pcb mounted jacks?
Much appreciated if you're willing to share!
markusw
Auke Haarsma
Nope, that doesn't contain the closed jack.
Thnx for the suggestion though!
I know it must exist somewhere. In this thread you can see a picture of someone who used it:
http://www.diystompboxes.com/smfforum/index.php?topic=55302.0
I pm-ed him a couple of days ago but got no response.
tranceracer
Maybe one of these will work?
con-lumberg/1503_?/1503_08
You can also use the pads in the "solpad" library and build a custom one.  I like to use the pads for custom components because I can label each pad and the pad label goes with it to the Board.
Auke Haarsma
Thanks, that one could be a kind of substitute. In the mean time I'm working on a custom one. If I succeed I'll share it (ofcourse)
Auke Haarsma
#5
Well, the Eagle-editor seems easy to use with the help of some tutorials on the web.
here's the lib I created:
http://www.mediafire.com/?afxz9xyylnd
It's a stereo closed mono jack.
There's still things to be improved, like the names of the pins, and probably the layout of the symbol. Feel free to do so if you know how to.
I've not tested it on a print yet, but will do so shortly.
Auke Haarsma
Here's an image of a project I'm working on with 4 of the custom closed jacks added:
I also made a print on paper and the actual closed jack pins fit the pads in eagle. Looks like you can use this one.
gaussmarkov
have you found some then?  i made some closed jack components based on the neutrik data sheets.  would they be helpful?
gaussmarkov
Quote from: gaussmarkov on February 11, 2008, 10:42:33 PM
just checked.  they are in the gm-jacks.lbr that has been up since december 20, 2007.  the packages are called MONOSW and STEREOSW where SW tells you that they are switched jacks.
http://gaussmarkov.net/eagle/lbr/gm-lbr.zip
Auke Haarsma
Thanks Paul, I have to check them out. I make heavy use of yourlibs...but have not updated them for a couple of months.
gaussmarkov
np.  i don't do a very good job of posting the changes anymore.  :icon_confused: :icon_wink:
