Pearl OC-7 Buid Report and a Question
Started by A.J., February 18, 2008, 10:33:29 AM
A.J.
OK - not so much a build report other than I used Mundry's layout (in Italian, but not a problem) based on Zeta55's layout - No issues putting this together (totally stock) - and it worked pretty much right off.
I was getting a lot of noise from offboard wiring being close to the 4013's - sort of a distorted ghost note on the clean channel - moved the wiring around and used shielded cable - seems to have done the trick.  Is that normal for those chips?
I really like the sound of this thing - it tracks incredibly well all over the fretboard, even with my very low output Ricky. Works ok even with the bridge pickup.  Seems to work best being fed a clean signal - fuzz before it is not so good, TS works better.
Good clean sounding octave downs - no comparison to the Blue Box.  I'm a little worried for my speakers, but I can't stop playing this thing.  My girlfriend threatened to leave when I brought out the Meatball (that's a fun sound).
My only complaint is that the octave up is a bit lacking and could be a bit more pronounced - has anyone had any experience tweaking this?
Cool build - highly recommend this one - thanks Mundry and Zeta for putting this one together...
A.J.
Morocotopo
Where do we find Mundry´s layout?
Morocotopo
Morocotopo
Morocotopo
Morocotopo
