CD4049UBE "UBE Screamer" issue...
Started by gregwbush, November 27, 2011, 06:45:39 AM
Joe
Quote from: Derringer on November 27, 2011, 02:08:56 PM
OT: Are they always a bit hissy?
N-channel MOSFETs always introduce noise, and therefore CMOS chips will too. The higher the gain/transistor count the more noise. One solution is to use only discrete P-channel transistors (like BS250), which have less of this problem.
DavenPaget
Quote from: Joe on December 11, 2011, 08:31:19 PM
Hissy in some circuits , but mostly unheard of in most MOS circuits .
Hiatus
gregwbush
AIIIIGHT,
I got off my ass and cut some perf!!!
the layout i'm following is that shown at RoG
I'm not done yet, but here's what i've done so far...
I've realized that not only is this my first logic 4049 build... it's my first perf-board build. I'm finding it... how you say;... interesting!
Well, i was finding it interesting... (and i'm sure this has happened to others)... but i ended up a little too sloshed and hadda put the iron down.
I'll continue tomorrow and POST results
(just previewing the post... to verify...i am in fact using solder, not tar, whatever the picture may depict)
cheers,
gregwbush
(jeeeez they really are bad photos, thought i was an expert. anyway when i'm done youz'll see  :P)
gregwbush
Sweeet
It works
i socketed the diodes and resistorX
So... what have i learned...
Component layout can be crucial in a high gain circuit!
Perfboard is quite cool
RunOffGroove know their $h!t
Oscillation by closely arranged parts doesn't necessarily cause an audible squeal or fundamental unwanted "tone"... it can be supersonic (above the audio spectrum) and cause all kinds of weird, instabilities and misbehavior of a circuit
Ummm
4049ube is a great package full of mosfet goodness, but must be utilized with some thought involved
UbeScreamer (even unshielded, as mine is, currently) is a nice circuit! I'm liking it for it's crunch, nasal tone AND it's ability to drive BSIAB2 into a nice lead tone. When i put it in a box it'll be even better
BTW, even unshielded... i'm not hearing "hiss" what so ever into clean channel. There is noise when boosting another overdrive. I dunno, define hiss
cheers,
gregwbush
thanks for everyone's input! I'll do a video and or sound clip and post (at some stage)
B Tremblay
I'm really glad that it is working well for you.  Thanks for sharing your build report!
B Tremblay
runoffgroove.com
gregwbush
Quote from: B Tremblay on December 16, 2011, 05:58:29 AM
You're welcome, i've learned a lot.
By all means feel free to use my pictures Mr RoG... i'll shove it on the scanner tomorrow if i can and do the top and bottom and you can use those on your website if ya want...
WGTP
As always I could be wrong, but raising the clipping Threshold on any of these types of devices, increases the output, but not the noise.  Try 4 silicons or 2 LED's for increased output/less distortion with less noise.  ;)
Stomping Out Sparks & Flames
DavenPaget
Quote from: WGTP on December 16, 2011, 01:33:37 PM
2 red 3mm led's .
Usually more gain = more noise , when you raise the clipping threshold you might be raising the noise threshold i believe , but that's just me  and i might be wrong :icon_mrgreen:
Hiatus
DavenPaget
Trem , what do you say about that feedback loop diode or a signal-to-ground diode ?
Hiatus
WGTP
Unless things are drastically wrong, the noise should be way below the clipping threshold.  Changing the diodes doesn't change the gain, but increases the output.  IIRC  ;)
gregwbush
Now there's an idea WGTP
I'll try that, and maybe adjust rx to compensate levels
Not looking for maximum distortion, far from it
Quote from: DavenPaget on December 16, 2011, 01:41:46 PM
2 red 3mm led's .
Nah nah nah nah nah... same gain, less clipping... no, wait, fuuaark... i'm confused now
You bloody poofters. I've got LED's, i'll do it now and see what happens
gregwbush
Ok i put 3mm red leds in...
Gotta turn the gain knob up to achieve clipping
It doesn't sound right. RoG schematic diodes sound better
There's less noise i think... but it sounds wrong
And now i gotta insert the diodes again... fiddly
cheers,
(shouldn't be drinking at 11am) gregwbush
