"Roller" pots ala boomerang?
Started by ianmgull, February 23, 2008, 11:55:55 PM
ianmgull
So I've never actually used on of those boomerang loop boards but I've noticed something interesting. There is a control that looks like some sort of "roller pot". I was wondering if anybody knew where to get a hold of something like this? Seems like it would be an interesting alternative to an expression pedal in certain applications
ian
bumblebee
roller pots are just regular pots with roller knobs and a bracket to mount them.
just have a look at a jaguar,same deal....the pots in my jag are just standard 16mm solid shaft pots.
ianmgull
Interesting. So I guess a more appropriate question would be where to find roller knobs and brackets?
bumblebee
Processaurus
I love those roller knobs!  Those and the old Maestro pedals with the crazy foot-rollable knobs.
I think you'd want to use a serious CTS pot with a big steel shaft.  Make the bracket after you have the pot and the knob (which you might have to fashion as well).  I think you could make one out of solid ABS rod.  A lathe would be best to center the 1/4" hole, but with some good measuring  you could just center tap it.  Drill a couple holes for set screws, and file the side of the pot shaft were they go, so that the knob doesn't slip on the shaft.
I think if you had a strurdy bracket and a beefy steel pot, it could withstand a reasonable amount of weight...
