What delay to build?
Started by drewl, February 26, 2008, 02:13:16 PM
drewl
Recommend me a good delay to build.
I guess around 1/2 second delay, possible hold function, maybe a sound on sound like a tape delay?
I could probably buy something like this cheap, even broken, but I was thinking of something to build to alleve my boredom at work.
I have a cheap Arion SAD delay pedal I could use for some parts if needed.
Thanks.
Auke Haarsma
If you want hold then you want digital.
drewl
It doesn't have to have a "hold".....maybe a looper built into it?
If you want anything that continues to recycle the input signal more than just a few iterations, then it MUST be digital if you expect to maintain any sort of signal recognizability.
drewl
No problem, I do digital all day....have tons of chips.
Thanks, keep the ideas coming.
