What do you DO with ROG effects?!?
Started by Praying_V, March 05, 2008, 07:33:42 PM
Praying_V
Well then!!  Here's another question:  Let's say I have several different amps.  Is each one's power amp "expecting" a different level of preamp signal?  I mean, could a preamp (solid state or tube) be freely swapped into different power amps, or would its output need to be tweaked depending on the power amp's design?
............................ken
MartyMart
Here's an MP3 of my little TDA2050 amp, can have whatever "pre" in front of it.
http://www.aronnelson.com/gallery/main.php/v/Martys-layouts-and-photos/tda_demo.mp3.html
Here's the thread, seemed to have the MP3 missing from it, that's why I posted it separately ??
http://www.diystompboxes.com/smfforum/index.php?topic=57018.0
Some interesting stuff in the thread .
No "OT" but a fine sounding "SS" amp all the same.
I did eventually put it in a large "Alu" box and used the box as the heat-sink ( isolator pad on the chip of course )
Marty.
DougH
#42
Quote from: Mark Hammer on March 08, 2008, 07:25:22 PM
My intent in suggesting use of output transformers was to permit use of traditional presence controls that actually use the input-to-output differences in transformer signal to clean up the signal.
Mark, a presence control is basically a low pass filter with variable fc that is in a negative feedback loop. The "input" is usually taken from the low voltage secondary side of the output transformer due to convenience, I suspect, as there is no high voltage DC component there. I don't think the xformer serves any purpose other than to provide DC isolation and scale the high signal voltage down to a more manageable level. You could do that with a divider and a cap but with the output xformer you already get that for free.
With 9v pedal circuits, this isn't an issue. Check the Axis Fuzz schematic for a good example of an NFB presence circuit used as a gain control in a fuzz pedal. Also- op amp based distortion pedals implement similar principles in their NFB-loop gain controls.
