Bazz Fuss gain trimmer = OSCILLATION?!?
Started by superferrite, March 11, 2008, 11:28:52 AM
superferrite
I put together a Bazz Fuss>BMP tone control>LPB1 combo to get some versatility out of this circuit but the 10K pot I used to control the gain (from the emitter to ground) causes a variable toneed WHEEEEEE when I turn it down past like a quarter of full.
The lugs are 1=emitter, 2 & 3 to ground.
What am I doing wrong?
The rest of the pedal sounds great, though...
Psychedelic Garage Metal
kismet78
Quote from: superferrite on March 11, 2008, 11:28:52 AM
I was doing something similar last night, except I tried the LPB1 and some other boosts in front of the Bazz Fuss. Talk about oscillation...
Sorry, that's no help.
superferrite
Did you put the transformer in the front end like it suggests?  I guess the circuit is subject to strangeness if anything is in front of it.
Still, the boost I have is in the back end.  Maybe I'll just build a whisker biscuit, although that doesn't have a gain trimmer either!
superferrite
Okay, some progress: The input cap directly effects the oscillation.
A larger cap (say, 1uf) makes it into a few barely audible clicks that increase as the pot is turned.
A smaller (<.01uf) cap makes it into the screel I previously described.
I'm using one Ge diode right now. if that makes a difference.  The 1n914 sounded less good.
I'm tracking something down, I think.
Anyone have any more suggestions?
mac
I wrote about biasing the BF by adding a large trimpot at the collector to get the most of it. If you put a trimmer at the emiter you may change the bias point, and possible tone and tightness.
Instead of changing bias, I'd use the 10k log pot as a standard drive control: lugs 1 and 3 to emiter and ground (or was it the other way??), lug 2 to bypass cap to gnd, 10-47uf.
Another drive control could be a pot between the diode and the collector. Never tried it, maybe someone already did it.
mac
superferrite
Mac,
I built the Synz Fuzz a few weeks ago, and that inspired this build.
I forgot about the bypass cap to ground (just looked at the schematic), and that may help the problems.
Already  have a 100K trimmer at the collector to bias it, but I get your point.
