How would I install this DC socket?
Started by BaLaClavaAa, March 17, 2008, 05:20:24 PM
BaLaClavaAa
I am building the dallas rangemaster by dragonfly and I am wondering what the wiring would be to add a dc socket since this is a negative ground circuit ( here is a url for a normal one http://www.generalguitargadgets.com/index.php?option=com_content&task=view&id=33&Itemid=27 )
BaLaClavaAa
Oops sorry here is the link to dragonfly's booster, though I don't think it's needed.
BaLaClavaAa
#2
BaLaClavaAa
Nope doesn't work =[, could someone else please have a go at showing me how to connect it, or provide a link or something. Thanks
Try swapping the battery+ and ring connections over.
Or do it like this http://www.generalguitargadgets.com/diagrams/switch_lo_3pdt_tb_dcj_pnp.gif
BaLaClavaAa
I tried wiring it like in the diagram, but it didn't work. When you said swap over the + and ring, did you mean on what I had before, or what I have after I had switched it  to what the diagram said?
Also I have done the circuit and everything like in dragonfly's layout, so I am using a dpdt switch if that makes a difference to the diagram.
BaLaClavaAa
Regardless I tried both, and neither worked, =[. So I have tried 4 different wirings now.
