stage bypass
Started by kismet78, March 20, 2008, 04:33:21 PM
kismet78
In a circuit like the Whisker Biscuit if I wanted to bypass the initial boost stage would it be feasible to use a spdt (input to center, outside lug 1 to boost stage, outside lug 2 inserted before coupling cap of fuzz stage)? Or would I also need to break the connection before the coupling cap when the boost is bypassed so the fuzz stage doesn't see the bypassed boost stage at all?
http://runoffgroove.com/whisker.html
Better way to do this?
kismet78
Is this a convoluted question or do you get what I'm asking?
kismet78
Mostly I need to know about potential loading from the bypassed boost stage on the fuzz if there is a permanent connection between the stages.
My searches have only turned up one thread with a similar question/answer, but I'd like some verification on the advice given in that thread:
http://www.diystompboxes.com/smfforum/index.php?topic=32965.0
