Anyone know what this component is?
Started by John Lyons, March 28, 2008, 08:49:25 AM
John Lyons
It looks like a surface mount part mounted inside a glass capsule.
It's marked 104M 50v 8330
Some others were marked with a J after three numbers as some caps are.
The 104 and 50v would seem to mean capacitor but who knows...
john
Basic Audio Pedals
www.basicaudio.net/
DougH
I think it's a cap. I have some .68u's that look like that.
John Lyons
Ok, then that confirms my suspicion.
Any idea what composition it may be or what this type is called?
I'm curious about the reason for the glass package. Maybe stability to environment?
John
Basic Audio Pedals
www.basicaudio.net/
Gus
I would guess ceramic .1uf 50V
I think you are right John is does look like a smd ceramic in a glass tube
BRingoC
That looks similar to a couple of the caps inside the doppelganger, or so it would seem to me, as I have only seen the pics posted on the forum.
Since when is 3/4 of the way up "cranked"?
boogietube
I think that it's a cap. I've got very similar looking ones that I bought surplus. My cap meter registers them as having the value that was on the package.
Sean
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
kurtlives
Quote from: Gus on March 28, 2008, 12:46:59 PM
Thats what I thought.
Maybe a germ diode wiht a cap inside. ::) ;D
My DIY site:
www.pdfelectronics.com
Pedal love
It looks like they might be a polystyrene caps.
Paul Perry (Frostwave)
I don't think it is polystyrene. It's too small.
I think it's an ordinary ceramic surface mount cap, that's been encapsulated in the same kind of machine that makes through-hole diodes from the original semiconductor dice.
It's kind of a good sign, if it means there are people busy turning smt into convenient packages !
George Giblet
I'm with Paul it's some kind of multilayer chip or monolythic ceramic capacitor.   I remember seeing these in the late 70's ad I still have a few around.
There is the glass types you have which were in the tens to hundreds of nF.  BTW  104M = 100nF 20%
There was also axial caps that looked like resistors.  The bigger ones like
http://www.robotroom.com/BigTrak/Capacitor.jpg
and the smaller ones like this,
http://commons.wikimedia.org/wiki/Image:Axial_capacitors_color_code.jpg
Then there were non-striped ones that looked like this,
http://www.iezone.com/exporter/product/135Multilayer%20Capacitor%20Axial%20Type.jpg
John Lyons
Thanks for the replys guys!
Those striped caps are interesting. Guess we know why the stopped making those!
John
Basic Audio Pedals
www.basicaudio.net/
