buffered a/b/y box phase swich popping
Started by newb, April 05, 2008, 06:28:24 PM
newb
hi im buildig a buffered a/b box from the plans in the gallery( the one that uses the tl074 but when swich the phase switch i get a pop.
is there a way to eliminate this?
thanks
Scott
newb
would a pull down resistor help? if so where would i put it? and what value?
soulsonic
Yeah, the polarity switches pop. I never bothered trying to get rid of it since it's not something you'd be messing with while playing. I suppose you could try putting some 1M resistors in parallel with the switch poles, that might help. It would be two resistors on each switch, one connected to each outer lug with the two joined together at the center lug. It would be worth a try.
