adding an "aftermarket" tube series to a ruby.
Started by baddayinparadise, April 24, 2008, 01:34:12 PM
baddayinparadise
I have a bread-boarded ruby, and I just got a 12ax7 tube. I want to add the tube booster section from the ruby tuby to my pre-existing ruby. Would I need to change any of the resistors or caps in my ruby to make them compatible?
party in the pants
finger in a wall socket
I'm the queen of France
baddayinparadise
also, I used a TL082 as opposed to a 072. Is the difference between a JFET opamp and a BiFET opamp enough to make it scream like a banshee?
party in the pants
signalpaths
If I'm not mistaken even 12ax7's have a cutoff of 12VDC.  A ruby amp is powered by 9VDC so in order to do what your talking about your gonna have to supply more voltage to the circuit somehow.
Eric
baddayinparadise
i've been using a regulated 12V source for the ruby, adn now i'm using it to power both. does the cutoff mean that that is the minimum voltage?
party in the pants
  12a_7 type 12v tube circuits barely get a tube working, headroom therefore output is small, just enough to get some bias on, and boost from.
  Apparently there's a sweet spot [using tubes designed for HV for LV boost] people have for LV tube circuits, I've tried only a couple.
