tone bender pinout
Started by foozertone, May 20, 2008, 03:21:32 PM
foozertone
I'm building a 3 knob tone bender using the three germ trans set from small bear. My problem is I can't find data sheets or pinouts for them. One is marked 2SB77 and has a mark for the collector pin. Another has no markings around the side but does sa 5N 1D SX on top of the can (it also has a tab denoting C?) The last one reads 3AX310 and has no tab or mark. Any help would be greatly appreciated.
Jeffrey
foxfire
the tab should be denoting the emitter. as for the last one if you're sockets you've got a 50/50 chance. also if the where the pins come out of the bottom of the can is in the shape of a triangle like this...  * E      i won't guarantee this but, it seems to work often enough.
                                     * B
                                  * C
