info on a pedal
Started by esurreal, August 04, 2008, 03:32:36 PM
esurreal
Hey, i'm looking to make a pedal that has two inputs and one output. Is this just a matter of hooking two input jacks together with one output jack. It will not need any "effect qualities". It only needs to transfer the two signals into one output. Thanks for any help!
E
theundeadelvis
If it ain't broke...   ...it will be soon.
esurreal
thanks! the passive a/b box is perfect if the two outputs are wired as inputs and the input is wired as output. There is not a schematic for this so any suggestions on how to wire it? thanks again
E
theundeadelvis
Since it's passive there is no difference in wiring. You just plug the amp in to single jack, and plug your instruments into the other two. So you'll be able to use the same pedal either way; switch between 2 amps or 2 instruments.
esurreal
cool but i think i have a problem. I somehow forgot to mention that i want the signals to be running at the same time. I don't want to switch between them. I'm thinking some little mixer pedal will work. Any suggestions?
E
esurreal
actually that mini mixer you linked to in the first response is perfect. I forgot about it..doh! thanks
E
theundeadelvis
You're welcome! I've built one, and it worked great. I made the channels foot-switchable.
