LFO for DELAYS (echo base lfo not working on +/-12v
Started by loss1234, May 24, 2008, 09:37:22 AM
loss1234
hey there
building an echo base for a rack device. everything works great on +/-12volts except the LFO section. anyone know if i should disregard the +5volts  on pins 6 and 3 of UA1/B? is this lfo super sensitive to specific voltages?
is there another easy OPAMP lfo i could stick in that will work on +/- 12volts?
i DID get the current sink input to work with an external LFO (tapping in at mod depth pot) so I KNOW the rest of the circuit works REALLY WELL. my god, this thing can do so many crazy sounds.
thanks
Use the one from the Roland M-172 module I posted on your other thread.
loss1234
i cant read that schematic...i tried hard but i cant
thanks
My redraw of the Roland LFO. the 0.01u cap can be adjusted to alter the speed range. The stock LFO just has triangle out, I found that the output of the first opamp gives a square too. the square is much higher output than the triangle though, you may want to attenuate it if you use it.
I have one of these running on +/-15 volts in my modular, another running on +/-6 volts using a 12 volt power supply and floating earth in a small SFX synth I built.
Do you still want me to redarw the Gate Delay?
If you're running it on +-12volts then pins 3 and 6 of the LFO and pins 3 and 5  of the other opamp should be connected to ground.
The LFO is just a standard 2 opamp triangle LFO running on a single supply. Normally you'd use a voltage divider to give you a 1/2 supply virtual ground, like you see in almost all stompboxes with opamps in, and connect the relevant pins to that. With the echo base I figured that as there was already a solid 5volt supply for the PT2399 I would save a few components and use that to bias the opamps as well. That's why the LFO doesn't like it if you run the echo base on a weak battery because the bias moves too far away from the centre of the supply.
By the way make sure you only run the CD4066 off +12 volts and ground not off +-12 volts, because its maximum working voltage is only 15 volts.
loss1234
hey everyone
frequency-thanks a lot! i would love the 555 gate delay but i felt bad about asking you to redraw it. :(
slacker-wow, you made the echobase eh? i CANT tell you how much i love it!
since i couldnt get the lfo working today, i had just plugged a JACK into the mod depth pot and WOW, ANY cv source i chose from my Modular synth opened up a whole new world of screwed up tones.
this has got to be the most powerful FX i have made in a long time, possibly ever. i am already in the process of ordering a bunch more pt2399 chips.
thanks
Quote from: loss1234 on May 24, 2008, 03:52:14 PM
Thanks, have you tried a sample and hold CV voltage that's really good fun :)
loss1234
yes i tried it
but i must say, my WOGGLEBUG was the best thing. if you havent built one i highly recommend (a grant richter design)
all in all, every module i plugged in sounded great. so i assume this is really just a CV in -is it linear? (i assume so as there is no expo converter)...is this what you might call a current sink?
anyway, thanks so much for such great work.
so simple to build to compared to BBD designs.
It's no problem my friend, I'll get down to it over the next day or so - I have a week off.
Also, I'm interested in a fellow modular user - what do you have? I have a 5 module Roland 100m with a further 8 DIY modules including Moog and Oberheim filters. 4 VCO, 4 VCF, 3 VCA, 4 ENV, clock dividers, sequencers, signal gates etc.
Quote from: loss1234 on May 24, 2008, 06:10:36 PM
I've looked at that a few times seem really interesting, I'll add it to the to do list.
Yes the base of the PNP transistor is basically a CV in, depending on what you're going to drive it with it might be worth adding a buffer in front of the "depth" pot, but most synth CV sources will probably be fine. The response is fairly linear, but to be honest I just  experimented with component values until it sounded good.
I think it's acting as a VCR (Voltage Controlled Resistor) rather than a current sink but I'm not too sure about the technicalities.
loss1234
slacker-very cool. i might try this circuit in other applications that need a VCR. very simple but works great.
my modular, well my modular is 100% DIY. i actually just started DIY last JULY (When i quit smoking) and i dived in head first. my first module was a kit (the PAIA midi 2 cv) but everything after that has been either veroboard or blank PCBS bought from ray wilson, ken stone, ian fritz,etc. (I SpEND LOTS OF TIME ON ELECTRO-MUSIC.com they have a great synth diy community)
anyway, i have about 14 modules now, some self designed, the rest are either standard fare (2 vcos, (ken stone and ray wilson) a ssm 2044 filter (foniktronik pcb)
an adsr, a multiple, a mixer, a wogglebug, 2 chaotic pattern vclfo's (ian fritz), a 4070 xor module, a cmos octave down (4040/4020) module, a diy serge negative/psotive slew (similar to the dual universal slope gen) a utility LFO (ken stone pcb) a ray wilson (self etched) sample and hold, a ken stone (pcb) vca, and a multi noise/random gates triggers module i etched myself.
there might be more..and THERE ARE a ton of pcbs i am still etching or populating. but for now i am working on a monster guitar effects box so the modular is happy as it is for a while. hell i spent a year building it and learning HOW to build it. build all my own panels and racks too. but it is NOT very pretty :)
sounds awesome though
