Standard Dynacomp mods (always on?) (script?)
Started by sjaltenb, June 04, 2008, 01:04:35 AM
sjaltenb
Hey yall.
I got tired of tweaking my BYOC dynacomp cuase i couldnt get it to sound right so i just bought a reissue. (byoc board for sale in sale/trade). Isnt there only like 1 or two value changes? It sounds fine for what I need it for but if its easy to change that would be cool too.
Also, what is the easiest way to send it to a 3PDT switch? I need to remove the switch that is on there now....
  I would think the BYOC board would be easier to work with.
  Values; many, changes; options, options.
  I would leave it alone if it's working.
  I would guess the only option is the hard way...
  It must be removed ?
  I would recommend build a Dynacomp the way you want it, or find a good compressor with the features you want.
  Re-issues IIRC are SMT, using Jfets to bypass, converting to true-bypass would be one slick trick if possible...I could be wrong...the recent MXR re-issues I saw and tried didn't look like much fun to fix or modify.
