positive ground rangemaster question
Started by 23, June 03, 2008, 04:29:51 PM
i built a positive ground rangemaster w/ an OC 71 tranny.. here s the layout
http://www.generalguitargadgets.com/diagrams/geb_rm_lo_pn.gif
hooked the battery up and blew the pot, sparks, smoke, fire etc... I did have the wire from lug2 laying across lug1 but it was the insulated part...so?
i was wondering if the jumper going from the collector of the tranny needs a resistor to stop the pot from sparking? and if anywhere else needs a resistor?
also if its needed what value?
thanks for advice.... scott
put it together, now take it apart
23
ok, 3k3 would work to lower the voltage to the pot all I need to know is if the jumper going to the pot needs to be replaced with a resistor or not? or Did i just screw this up with the wire across the lug or was it possible it was a bad pot....
common some help please?
