(New forumite) - Help with switching !!!
Started by DSV, June 21, 2008, 02:10:05 PM
DSV
Hi all! 1st post here!  :D And already bugging you with questions  ;D
For my next project (I've made a few stompboxes) I'm going to build a 3 channel preamp for my guitar, and I'm having a bit of trouble with the switching section.
My goal is to have:
- 3 footswitches, each one activating its corresponding channel and deactivating the others,
or
- 2 footswitches, the 1st selecting channel 1 (and deactivating channel 2 or 3), and the second recalling the channel which was in use before selecting ch. 1, and then switching between channel 2 and 3.
Furthermore, this switching system should not need a dedicated power supply.
Finally, the footwitches should, if possible, not be in the same enclosure as the preamp (which I think means I'll have to find a sitable connector between them).
I have only experience with mechanical 2PDT and 3PDT switches, but none with other types, which I think are needed for this. My searches on this forum and other places haven't given good results, basically because I don't really know what to look for.  ::)
I saw there are relays, and also other switching circuits (CD4066?), but I couldn't find some concrete examples or simple tutorials for them.
Have you got a schematic which performs what I need? Or a link to a good explanation about their work?
Thanks,
DSV
Roobin
Have a look at GEOFEX.com - IIRC there are a number of digital switchers and relays.
DSV
Thanks. I also found some good resources on the ToneGod site.
Basically now I have in mind what I want to do for the channel switching:
                   *--------------- CH1 --------------*
in --SW1a                *---- CH2 ----*                SW1b-- out
                   *-SW2a                       SW2b-*
                               *---- CH3 ----*
and the LED indicators:
                   *-----------LED1----Resistor----GND
V+ --SW1c                 *---LED2----Resistor----GND
                   *-SW2c
                                 *---LED3----Resistor----GND
This could be done with 2 3PDT footswitches, however I'd prefer a separate 'pedal' for controls.
I think I have understood the general principle behind the switching. However I still have got some points to clarify:
- which is better, the CD4066 or the 4053 ?
- if I use the 4053, can I use the 3rd 'switch' to hook up an indicator LED (basically I'd like to switch between ground and V+) without damaging the circuit ?
- what is better, momentary or latching switches (and correspondinf implementations) ? I can find both kinds of footswitches at the same price.
- the footswitch I'd like to use would be connected with the preamp through a stereo cable, for GND, S1 and S2. Is there a way to add indicator LEDs in the control pedal, without using a battery ?
Thanks,
DSV
DSV
I have checked the datasheets of the 4053 and 4066. They both offer the same resistance to the signal path when engaged, so I think there should be no audible difference when in operation.
My choice will then be based on the better configuration. The three channels are basically 3 Sansamp GT2s. I'd like to know which could be the best place in order to add these switches.
Judging from the schematic at Tonepad, I think there are 3 possibilities.
1st one:
- I can 'split' the signal after the 22n cap and 10k resistor (point A), by wiring the 3 GT2s in parallel (fig 1). I don't think this should cause audible treble loss, since the driven impedance is pretty high (~= 100Mohms). So no switch here.
- I can select the channel after IC4b (point B, just before the output buffer), or at the output C (I will add another buffer, in order to have a controllable output line out, or a headphone amp.)
2nd one:
- I select the channel at point A;
- I mix all the channels after IC4b, or the output buffer
3rd one:
- I select each channel both at point A and at the output (like a DPDT switch configuration).
In all these configurations, there is no need for the 1M pulldown resistor at the input.
Which one do you think is best ?
~arph
