dual coil latching relay: wired up right?
Started by chieljan, July 01, 2008, 04:30:57 AM
chieljan
Hey All!
Read everything on geofex on relays, so I'd like to check if I understood everything:
Did I wire this 2-coil latching relay up correctly to prevent pops?
I added a diode across the coils, maybe there should be a 10 uF cap too?
*can't seem to place the image inside this post, it's on http://profile.imageshack.us/user/chieljan/images/detail/#48/switchrelay2hd3.png*
I'm the Dude. So that's what you call me. That, or His Dudeness or Duder or El Duderino if you're not into that whole brevity thing.
