importing pcb image to cad software?
Started by fogwolf, June 29, 2008, 02:54:13 PM
fogwolf
If there's a project on Tonepad or GGG in PDF format and I wanted to make changes to the transfer PCB image, how would I get this into cad software? Would I have to manually re-draw or is there an easier way?
Thanks.
You would first ask the copyright owner for permission to make a derivative work. Control of derivative works is one of the rights in "copyright".
fogwolf
Okay. Even for personal use (non-commercial)? Didn't realize that. Thanks.
Quote from: R.G. on June 29, 2008, 07:50:50 PM
Of course, given the proper assurances that it's a one-off, one-time personal-use-only item and will not then be dusted across the internet, most copyright owners would say "sure".
But yes, by the letter of the law even one-time personal use only derivative works are covered under copyright. It's patents where a single personal use copy is allowed without permission.
fogwolf
Good to know. Thank you.
Quote from: R.G. on June 30, 2008, 08:35:28 AM
alanlan
Quote from: fogwolf on June 29, 2008, 02:54:13 PM
Thanks.
I don't know about doing it with Cad software - if you were to go down this route, you probably would be better off starting with the circuit + your mods and taking the existing layout as a guide.  If you're just doing minor tweaks from an image in a pdf you would probably be better off using an ordinary drawing tool.
fogwolf
Thanks - any specific drawing program you would recommend (I have both a Mac and a PC)?
Quote from: alanlan on June 30, 2008, 02:37:31 PM
Thanks.
alanlan
For Cad, I use Eagle (works well on a Mac) but there are others.  For drawing, you could simply use Paint or similar.
Paul Perry (Frostwave)
I'm sure there are plenty of free progs for converting tiff or gif to the various cad formats.
What you are trying to do, is convert raster art to vector graphics. (if by 'cad' you mean drawing programs).
usually easier with tiff or gif starting point, so you don't have work through jpg (problems with artifacts).
darron
pdf and cad are both vector formats, and both formats supported by illustrator and many other vector imaging programs. all that you'd need to do is import the file and re-export it as cad. i think i actually needed to get an export plugin for illustrator to do that, but they are really easy to find on the web.
but then you hit the problem that most of those guys have password protected their files, making it a pain in the arse to import them into anything except acrobat or your browser to print ect. properly. so you'd have to break the password and go against their wishes.
OR you could rasterise the image, bring it into the imaging software and convert it to vector. it's not AS good of an idea but at least it would work if you needed to feed it into a machine that would only take cad.
fogwolf
Thanks for all the information.
By the way for those (like myself) who don't have Illustrator, I found this free open source 2D vector illustration program - http://www.inkscape.org/ - haven't tried it yet but from what I've read so far it should be able to import a PDF file and export to dxf.
Quote from: darron on July 01, 2008, 05:24:45 AM
