DOD Overdrive 250 & 10uF tantalum in C1 position?
Started by Rocket Roll, March 09, 2008, 10:58:42 AM
Rocket Roll
Hi! A quick question, as I'm really in a conundrum?
Build - DOD Overdrive 250 from GGG site ( http://www.generalguitargadgets.com/index.php?option=com_content&task=view&id=102&Itemid=26 )
Schematic: http://www.generalguitargadgets.com/diagrams/dist_250_sc.gif
Bill of Materials: http://www.generalguitargadgets.com/bom/dist_250_bm.txt
Parts Layout: http://www.generalguitargadgets.com/diagrams/dist_250_lo.gif
Question: C1 is supposed to be 10uF aluminum electrolytic. Can I use 10 uF tantalum in it's place? I have one that's marked as Philips (10 uF, 16V).
(Thank you very much in advance! This is a great forum and I prefer reading & learning to posting & asking questions, but I'm really unsure this time.)
"Goin' down where Southern cross' the Dog"
Short answer is YES.  C1 is not part of the audio path.  It merely smooths out the bias voltage  A 100uf cap from the R12/R2 junction to ground would provide a little more hum-immunity if you are using a wallwart to power it.
Rocket Roll
Joe Hart
Mark, do you mean add another cap to ground at that junction or just make C1 a 100uf cap?  C1 is not at the junction of R12 and R2.  Thanks.
-Joe Hart
96ecss
Hi, you would add a cap to ground as pictured here in the Liquid Drive schematic from Fuzz Central http://fuzzcentral.ssguitar.com/liquid.php
Here is how Phillip Bryant describes it's function "To add some extra nose rejection and polarity protection to the circuit, I've added a 100-ohm resistor in series with the power supply before the power makes it to the circuit, and then I added a 100µF Electrolytic and 0.1µF Cermaic capacitor in parallel with the power supply after the series resistor. These two added capacitors provide superior noise/hum rejection for the circuit."
I hope this is helpful
Dave
Rocket Roll
It is, thanks a lot!
Btw, so far my DOD looks like this (it's constantly changing):
96ecss
Looks good. Ilike the Jake and Elwood sticker.
How about some sound clips?
Dave
