Easy fuzz bias question- I should know this
Started by jimbob, July 16, 2008, 02:30:12 PM
jimbob
I have a set of germ transistors from small bear that came with values. I used these same values and it seems the bias is off. The resistor listed for what would normally be a 8.2k or a 10k trim is listed as a 12k resistor. I used a 12k and still not right. What could/would/should I use as a trim pot to bias? 20k pot? etc?? I tried a 20kw I had lying around from a Tube screamer build and it really didn't go right. Am I off here in my train of thought?
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
John Lyons
The resistor off the collector is the one you want.
With a 20K pot as a trimmer you should be able to dial in 4.5v or close.
What voltages were you able to get. (measured at the collector of course)
john
Basic Audio Pedals
www.basicaudio.net/
