Can anyone recommend a good layout creator that is MAC compatable???
Started by signalpaths, July 26, 2008, 12:03:29 AM
signalpaths
So far I've found one but it doesn't want to work on my computer.  What do you mac users use? ;D
caress
osmond quartz is the only one i've found, although i don't like it very much.  it's not very friendly...  :P
Seljer
any
Quote from: caress on July 26, 2008, 12:43:18 AM
I quite like Osmond Quartz, once you get the hang of it.
It's free for projects up to 5000 tie points (as far as I can remember) so almost any
stompbox schem will be within those limits.
It has some nice features as a visible trace check (to see what's connected together) and does
very nice rounded corners as well. Just make sure you download some libraries to get started on some parts
or create your own.
Cheers
It's supposed to sound that way.
signalpaths
mac
There is another solution but not recommended: HD partition and installing Windows. The problem is all the nasties you can download from the net that can destroy your info.
I've been using macs since the first 128K and never had a virus problem.
mac
any
Oh, and not to forget... Bancika's DIY layout creator runs on Mac now...
tried it and it's quite a joy to use, real easy... has some small bugs still but nothing annoying.
