Another transistor to replace BC560?
Started by ppatchmods, July 30, 2008, 12:46:44 PM
ppatchmods
I'm building an echobase and am looking for a transistor that could replace the bc560 to save on shipping from another supplier.  Any suggestons?  Thanks
When your life is over, will any of this STUFF really matter?
People have reported that a 2n5087 works fine. Pretty much any high gain PNP should work.
ppatchmods
the specs call for a 2n5089 and a bc560...so could i just use 2- 2n5089's?
No, a 2n5089 is an NPN transistor, the one in the BC560 position needs to be a PNP.
maartendh
Hello,
with the BC-type you have to look at the suffix:
BC560-A has a gain (Hfe) of 110-220, BC 560-B is 200 - 450 and the BC560-C will give you between 420 and 800.
BC 557, 558 and 559 are essentially the same pnp's (max voltage and/or frequency limits might differ, but this usually is not relevant, e.g. assuming you are operating at 9 or 12 volts and amplifying audio frequencies). BC560 is lower in noise than these other pnp's.
Maarten de Huu
There used to be a  useful cross reference guide here ( www.ee.washington.edu/circuit_archive/parts/cross.html ) but now that address gets you to the NTE cross reference guide. Using that, when you search for the BC560, 2N5087, or a 2N3906 the same NTE159 comes up as a replacement for all. So that would imply at least any of those four would work in the circuit.
dave
