Meatball pcb problem...
Started by chicago_mike, August 07, 2008, 10:54:27 AM
chicago_mike
The TL074 pins on the pcb are too close together...
I printed it to scale. Is this an older pcb drawing?
axg20202
Is what an older drawing? You need to give us more info.
EDIT: did you use the project file in this thread?:
http://www.diystompboxes.com/smfforum/index.php?topic=69737.0
I can't remember having to scale this PDF when I made the McMeat, but you may need to. Just adjust until the IC fits and all should be well.
chicago_mike
Sorry about that. Yeah I meant the McMeat.
Its wierd because the TL072 fit in just fine..But I can always make another. :icon_smile:
MarcoMike
I made mine from the mcMeat pdf and had no problems. the 074 fits just fine...
Only those who attempt the absurd will achieve the impossible.
