single penthode guitar preamp???
Started by vasko, August 18, 2008, 06:05:11 PM
vasko
is it possible to make such preamp?
I'd like to use ef80.I also have ecc82 triode.
It has to have gain,treble and bass knob.
I want to use it to attach guitar with PC line in.
Renegadrian
ATM there's not much about pentodes...I got some and will start breadboarding in a while...Until now, you can find a couple of 6418 projects in the gallery. See if they may be helpful....
Got ECC82??? BUILD A VALVY!!!  :icon_wink:
Jimmy-H
Quote from: vasko on August 18, 2008, 06:05:11 PM
Only found this, but it's with a different tube 6AU6 en 36volt DC : http://jonanderson.mn.googlepages.com/tubebooster
comfortably_numb
Should be easy to design using a space charge tube, referencing that schematic.
vasko
Jimmy-H ,this got no bass,gain,treble contrtols...and how is this penthode working on 36 V???? Usually tubes use 300V...all bellow 100V is "fishy" to me
Quote from: Renegadrian on August 18, 2008, 07:19:01 PMGot ECC82??? BUILD A VALVY!!!  :icon_wink:
is this valvy?  http://www.beavisaudio.com/Projects/ValveCaster/MatsuminValveCaster.gif
same...9V ...no way this is gonna work
Renegadrian
GRRRRRRRRRRRRRRRR :icon_evil:
How'd you say it cannot work?!?!? Just try one!!!
You have to understand that tubes aren't only for those high voltages...12V can make quite a sound!!!
