Wiring Help, Orange Sunshine Fuzz
Started by optionbenjamin, August 21, 2008, 05:40:27 PM
optionbenjamin
Hi guys! I'm trying to wire Dragonfly's Orange Sunshine for 3pdt +led, based on the following layout:
http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/album18/album151/ORANGE_SUNSHINE_FUZZ_PERFBOARD_001.gif.html
I've been using tonepad's offboard wiring for other projects, but as there is no circuit output marked on the layout I'm sort of stuck...
I assume that since there are tons of layouts without an output marked that it should be self-explanatory...I'm pretty new to pedal-building.
Any help would be greatly appreciated. I'm basically all wired up per tonepad except for one lug of the switch which is supposed to wire to the circuit output, and I am also left with an empty lug on the pot (lug 2, which might tie to another lug?).
You guys are fantastic, this has been an absolute joy of a hobby and I'm so thankful these resources exist!
Ben
demonstar
Hey there, if you look at the parts list on the drawing it says the middle lug on the pot is the output. So hook a wire up to the middle lug on the volume pot and use that as your output and you're ready to go.
Hope that helps!
"If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut"  Words of Albert Einstein
optionbenjamin
Thanks for the speedy reply! I actually tried this before and got no signal, only bypass. Might be a bad joint or something, but this is one less possible error, which makes it a huge help. Thanks so much! Really!
Ben
ralley
Looking at that layout the output comes off the top right of the board at A-13 and goes into the volume pot, lug 3.  Lug 2 (wiper) of the volume pot is then your effect out, this is what you would wire to your switch.
Damn, beaten to it by demonstar. :-)
Rob.
Sender lawyers, guns and money
The sh*t has hit the fan.
   - Warren Zevon
