Can i add an LED?
Started by lerxst88, August 25, 2008, 02:31:51 PM
lerxst88
i have an old mxr distortion+ with no LED and i want to put one in. problem is it has a SPDT stomp switch and the local radio shack doesnt have any stomp switches. could i wire it up like this?
frokost
That won't work. This way, the signal would have to go through both the LED and the resistor, and that's not what you want. Either buy yourself a 3PDT switch or leave the unit as is for original mojo (and $$$) value.
You could use Millenium bypass, find it here: http://www.geofex.com/
Renegadrian
Yeah, but he should have a DPDT, Am I right???
ianmgull
foxfire
#5
and it would be a tight fit. i'd keep the original original and make a new even more better one.
rock_god_dan
you'll need at least a dpdt, but better if you get your hands on a 3pdt  :)
