LFO Rate LED causing audible ticking - Any good ideas the stop this?
Started by frequencycentral, August 25, 2008, 03:06:56 PM
I guess it's different to bypass LED popping: http://www.muzique.com/lab/led.htm
Circuit: http://www.diystompboxes.com/smfforum/index.php?topic=70160.0
I'm connecting the LED via a 4K7 resistor to the emitter of the second BC547C.
Shouldn't really be all that different.  It's the same challenge: softening the sudden current draw from a device.  One solution is to use a high-brightness LED and a larger value current limiting resistor.
niopren
Thanks, I just tried a 1n4148 in series with LED, seems to help!
GibsonGM
the 100 ohm series resistor, plus a 1000 uF cap from V+ to ground where it enters the board, often works wonders for LFO ticking...
