adding an LED to a Red Ranger
Started by studiostud, September 10, 2008, 02:24:22 PM
studiostud
Hey guys,
I have a red ranger circuit from Tonepad and I would like to add an LED to the configuration so that when the on-on-on switch is in center (full), the LED is off and when it is on either side (bass/treble), the LED is on.  How would I go about doing this?
Builds Completed: Big Muff. Fuzz Face. Tube Screamer. Rat. Crash Sync. Harmonic Jerkulator. 6-band EQ. Rebote 2.5. Tremulus Lune. Small Stone. Small Clone. Microamp. LPB-2. Green Ringer. Red Ranger. Orange Squeezer. SansAmp. MXR Headphone Amp. Bass Fuzz.
MikeH
You'll need a switch with another pole, so a 3pdt on/off/on (according to the layout it uses an on/off/on switch, not on/on/on).  Take the extra pole and connect the outer lugs to 9v+, the center to LED+ and the LED- to ground with a resistor in between ground and the LED or 9v+ and the LED.  Your choice.
