Field Effect Pentode Transistor?
Started by Jered, September 09, 2008, 06:13:34 AM
Jered
  Does anybody know anything about these? I wonder if they will work for small signal audio?
http://www.freepatentsonline.com/4104673.html
Steben
something like this?
or this?
The dual gate FET is compared to multi-grid tubes, so I guess it is something like this.
Sir H C
Not good for audio.  Those are devices made to run at 20 GHz in a GaAs process.  Similar to cascoding but with that fifth terminal.  The patent is from the late 70s and I have not ever seen one in use, so I would assume it was a dead end.
Jered
Quote from: Sir H C on September 09, 2008, 09:53:55 AM
  That was exactly what I was wondering. I've never seen them either. Thank you Sir.
DDD
As far as I know there is JFET tetrode exists. It's a low power small signal JFET with two SEPARATE gates designed in the USSR and still produced in Russia. Its mark is "ÊÏ304" if I remember truly.
Sir H C
Dual gate devices are here too.  Usually for high frequency RF where the second gate acts like a cascode device to lower the parasitic capacitance from input to output (to reduce tendency to oscillate and to raise the input impedance).  Where I used to work, one of the research guys was really into his dual-gate devices.  It got to where we would parody his way of saying duuualll gate.
