Small Bear switches
Started by bancika, September 30, 2008, 09:53:02 AM
bancika
Anyone knows if these are solder lug or pcb mount switches? I can't tell for sure from the pic
http://www.smallbearelec.com/Detail.bok?no=42&sfs=8c1b96e0
Tnx,
Bane
danielzink
Someone is going to call me a hack - or say "that's a redneck way to do it" but...............
If I see lugs off the botton of a switch (or even a 9mm pc mount pot for instance) - I see a solder lug....
If there's tab sticking off the bottom of it - you can solder to it. I use alligator clips, those "third hand" things that have the magnifying glass and the bendy alligator clips - whatever it takes to hold the wire to the lug so you can heat both up to get some solder to 'em.
You can see the 9mm (pc mount) pots in this picture:
Dan
bancika
yeah, I know, but it's for tube amp, I wanna do it "the right way" :)
Zedmin_fx
Quote from: bancika on September 30, 2008, 01:25:16 PM
you could alway drill them thats what I do.
bancika
Zedmin_fx
drill small holes in the lugs for you wire.
Quote from: Zedmin_fx on September 30, 2008, 01:46:58 PM
According to the datasheet the pins on the Small Bear switches are less then a millimeter wide, you're going to need some pretty tiny gear to drill a hole in them. :icon_wink:
I've got some of these from Digikey, they should do what you want. http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=360-1788-ND
dave
bancika
At the end I took those mountain switches at small bear, they are a bit pricey ($2.7 each) but what a heck :)
