Combining a ITS8 and a LPB-1 into one Hammond 1590BB Case (both fromm ggg)
Started by T-Dub, October 08, 2008, 08:20:43 AM
T-Dub
Hey there,
it's a little overly ambitious for a first build, but I'm trying to combine the two of these into one pedal.
Basically, I want to be able to use the lpb-1 to clean boost the ITS8, but have both circuits able to be used independently as well.
I've got both PCB's on the way, and the ITS8 is a kit. My question is this; what potential problems (barring newb muckups) can you see with this?
Auke Haarsma
the most difficult thing will be the layout of switches, pots, jacks and pcbs in the enclosure. Pay good attention to that before starting to drill!
zeeman
You get a 10 for enthusiasm, but...
If this is your first build and you do not have some electronics experience, I would suggest that you start off slow.
I would first build the LPB and see how that goes.
Then take it up a notch (or two) and go for the ITS8.
Good luck.
zeeman
