5K Rev Pot? (Can't find em)
Started by Evad Nomenclature, October 10, 2008, 11:53:56 PM
Evad Nomenclature
I did a build today for a boost pedal that calls for a 5k rev pot.
Can't seem to find them anywhere.
Anyone know anywhere I could get one, or any other solution or substitution?
thanks!
Evad Nomenclature III
Master of Dolphin Technologies
dschwartz
Tubes are overrated!!
http://www.simplifieramp.com
Quote from: Evad Nomenclature on October 10, 2008, 11:53:56 PM
thanks!
Small Bear have them in Alpha 16mm and 9mm sizes.
http://www.smallbearelec.com/Detail.bok?no=693
http://www.smallbearelec.com/Detail.bok?no=116
You could also wire in the regular 5ka backwards, swapping the outside terminals.
dave
Evad Nomenclature
kurtlives
If this is for a SHO a 5K audio pot works nicely.
My DIY site:
www.pdfelectronics.com
Zben3129
5k linear pot is a better match to 5k rev than a 5k audio
If you wire a 5k audio backwards, you will get rev audio, but you will also have to turn the knob IN THE OPPOSITE DIRECTION
heres a 16mm alpha 5k reverse taper   http://www.pedalpartsplus.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PPP&Product_Code=7516&Category_Code=Pot16R
