Omega booster vero?
Started by greenacarina, October 30, 2008, 12:17:00 PM
greenacarina
Built this one and currently troubleshooting. Can anyone verify the pinouts of the transistors??? This is the only very layout I could find-
http://www.diystompboxes.com/smfforum/index.php?topic=63286.0
Thanks.
Chris
MikeH
It depends on the manufacturer.  Different companies produce the same transistors with different pinouts.  You have to look up the datasheet from your manufacturer, and if you don't know it, trial and error is pretty much the only route.
greenacarina
Well, I should have clarified a bit that I was wondering how things should be labeled on that layout?
And that previous bit about pinouts being different from mfr to mfr is VERY timely as I am having issues with another project an I think that is the key!!!
Thank you!!
Chris
