Can I Use This Reverb Tank?
Started by Zben3129, November 16, 2008, 05:30:12 PM
Zben3129
I recently got a broken Behringer Keyboard amp, and it had a reverb tank in it.
I can't find a part number anywhere (missing panel), so all I could do is measure the tank with a DMM. The input measured 95 ohms and the output measured 375. Is there any way to put this tank to use (preferrably solid state)
Zach
mth5044
I've never heard of a reverb tank with such a low output resistance. The stage center reverb takes 300 something input, so you may be able to adapt something from that, not sure.
You could also compare it to the accutronics tanks:
http://www.accutronicsreverb.com/prodspec.htm
good luck.
