bazz fuss
Started by 23, November 18, 2008, 08:49:32 PM
What would be the best input cap for the bazz fuss that would preserve the whole spectrum of the bass ( not cutting to many lows or boosting the highs?)
and can I put a 500k pot between q1(MPSA13) to ground for something similar as a dirt control?
any help thanks
put it together, now take it apart
leigh
Do a search for the Deluxe Bazz Fuss... I believe for a dirt control they used a 1K from the emitter to ground...
23
Ok I got all the mods I want except for what caps to use for the input, I want something that will preserve the lows and highs of the bass........... any ideas where to start would be helpful. This is the first bass pedal Ive ever built.
23
ANY ONE GOT ANY SUGGESTIONS ON A DIY PROJECT FOR BASS SIMILAR TO THE    HAO RUST DRIVER?
GibsonGM
Mess around with the cap value, try .68uF, 1uF, 10uF....see what you like best!
jonjon
I used a 10 uf for my in and output caps works well on the bass. Ive heard 4.7uf id good too. but I dint have any on hand to try out
john
23
thank you... its not that I'm not willing to do the work or just stupid... I just dont have a lot of stock of things and need some parameters to order between...
