XLR Microphone killswitch
Started by mr.adambeck, November 24, 2008, 03:28:02 PM
mr.adambeck
Does anyone have a layout to make a killswitch for XLR?  I assume this is pretty easy, but I know nothing about XLR wiring...
.Mike
Here you go:
http://www.procosound.com/downloads/datasheets/Old%20Version%20of%20Cough%20Drop.pdf
The schematic is right there at the bottom. It's very simple.
I have one of these actual units. Oddly enough, mine has no capacitor and no resistor. It worked fine with no popping in my tests using both a dynamic mic and condenser mic, but I've only used it for maybe two minutes total.
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
d95err
The cap is there to block DC when using phantom power. Without it, you will be shunting the phantom supply directly to ground.
