Looking for a simple LFO layout
Started by Nitefly182, December 02, 2008, 07:26:53 PM
Nitefly182
Im trying to figure out a way to modulate the delay time on the new BYOC analog delay for modulated repeats but I cant seem to come up with a good simple LFO to run an LED/photocell combo to run in series with the delay time pot. Anyone have any advice?
Zben3129
why don't you try the EA trem LFO or a chorus (CE2 for exampe) LFO?
Zach
ForcedFire
I used the LFO from the Tremulus Lune in my delay build, you can just take the top right corner of the PCB layout if you want. The two leads running down from the op-amp are positive and ground. Just wire in resistors wherever you don't want pots.
http://www.diystompboxes.com/smfforum/index.php?topic=72527.0
