Beginning mod-er : what component values to buy?
Started by timmyo, November 22, 2008, 10:02:22 AM
timmyo
I keep threatening to jump in and start modding pedals and now is the time. I'm going to put in an order to Rapid (UK-based supplier) for an initial stash of components to ahve to hand, and was wondering if collating a sensible pedal-modders-stash-list is something that had been done before (rather than me sift through mod schenaatics and draw up a list, which I'll do if I have to)
cheers,
Tim
dano12
timmyo
Cheers man - top page, hadn't seen that one.
I have been toying with ordering a Beavis Board, but i guess I'm just being cheap  :icon_redface:
timmyo
OK an initial stab at this:
http://www.rapidonline.com/Electronic-Components/Discrete-Semiconductors/Signal-Diodes/Signal-diodes/66259/kw/1N914
1N914 75V SIGNAL DIODE (RC)
http://www.rapidonline.com/Electronic-Components/Discrete-Semiconductors/Signal-Diodes/1N4148-Signal-diode/66244/kw/1N4148
1N4148 75V 150MA SIGNAL DIODE. (RC)
http://www.rapidonline.com/Electronic-Components/Discrete-Semiconductors/Zener-Diodes/1.3W-BZX85-Series-Zener-diodes/80688/kw/Zener
Zener diodes - which ones?
http://www.rapidonline.com/productinfo.aspx?&tier1=Cables+%26+Connectors&tier2=Connectors+-+Multipole&tier3=SIL+Sockets&tier4=Low+profile+turned+pin+2.54mm+SIL+sockets&moduleno=63758&catref=22-1702
20 WAY TURNED PIN SIL SOCKET(RC)
http://www.rapidonline.com/productinfo.aspx?&tier1=Cables+%26+Connectors&tier2=Connectors+-+Multipole&tier3=DIL+Sockets&tier4=Low+profile+DIL+IC+sockets&moduleno=63772&catref=22-0131
TUBE (50) 8 PIN 0.3IN DIL SOCKET
http://www.rapidonline.com/productinfo.aspx?tier1URL=Electronic-Components&tier2URL=Capacitors&tier3URL=Ceramic&tier4URL=224-piece-Ceramic-capacitor-kit&moduleno=74260&kw=Ceramic+capacitor+kit#techspec
Ceramic Caps :
21x   10pF, 100pF, 1nF, 10nF, 100nF
14x   22pF, 47pF, 220pF, 47pF, 2.2nF, 4.7nF, 22nF, 47nF
7x   220nF
http://www.rapidonline.com/Electronic-Components/Capacitors/Polyester/Miniature-polyester-capacitor-kit/62509/kw/polyester%20capacitor
Miniature Polyester Caps :
15 x 1n   10 x 4n7   10 x 22n
10 x 2n2   15 x 10n   10 x 47n
20 x 100n   5 x 470n   5 x 220n
http://www.rapidonline.com/Electronic-Components/Capacitors/Radial-Electrolytic/Radial-electrolytic-capacitor-kit/62537/kw/capacitor%20kit
Radial Electrolytic capacitor :
Contents:
10 x 1µ 63V   15 x 10µ 25V   15 x 100µ 16V   3 x 1000µ 16V
10 x 2µ2 63V   5 x 22µ 25V   5 x 220µ 16V   3 x 1000µ 25V
10 x 4µ7 63V   10 x 47µ 25V   5 x 470µ 16V   2 x 2220µ 16V
http://www.rapidonline.com/productinfo.aspx?&tier1=Electronic+Components&tier2=Resistors+%26+Potentiometer&tier3=Metal+Film+Resistors&tier4=MR25+Metal+film+resistor+kit&moduleno=65199&catref=13-0270
Metal Film Resistors
10 x 10R   10 x 150R   10 x 910R   15 x 5K6   15 x 33K   15 x 220K
10 x 15R   10 x 180R   20 x 1K   15 x 6K8   10 x 39K   10 x 240K
10 x 22R   20 x 220R   20 x 1K2   10 x 7K5   10 x 43K   10 x 270K
10 x 33R   20 x 270R   15 x 1K5   10 x 8K2   20 x 47K   20 x 330K
10 x 39R   30 x 330R   10 x 1K8   30 x 10K   15 x 56K   10 x 390K
15 x 47R   10 x 390R   10 x 2K   15 x 12K   10 x 68K   20 x 470K
10 x 56R   10 x 430R   20 x 2K2   15 x 15K   10 x 75K   10 x 560K
10 x 68R   20 x 470R   10 x 2K7   10 x 16K   10 x 82K   10 x 680K
10 x 75R   10 x 560R   15 x 3K3   10 x 18K   40 x 100K   10 x 820K
10 x 91R   10 x 620R   10 x 3K9   10 x 20K   15 x 120K   30 x 1M
30 x 100R   20 x 680R   25 x 4K7   20 x 22K   10 x 150K
10 x 120R   10 x 820R   10 x 5K1   15 x 27K   10 x 180K
comments?
Looks like a good selection for modding pedals, and if you decide to move over to making some, it will make a good start to your stash.
If you want the zener diodes for clipping then you probably want low voltage ones 4 or 5 volts max. I would maybe get some LEDs instead as they are commonly used in pedal mods.
Joe Hart
I've had great success with what Homer Simpson calls "Crappenfest" -- trash collection day (and it comes 52 times a year!). Here are 5 easy steps to make the most out of your next Crappenfest:
1 - Cruise around and grab all the old radios, TV's, VCR's, etc. that people leave out on the curb.
2 - Once back home, open your presents with a hammer, screwdriver, crowbar, rock, whatever.
3 - Pull out all the circuit boards, marvel at all the "mojo" components, then toss all the boards into a big cardboard box.
4 - Throw out all the smashed up plastic.
5 - When you need a component, locate it on one of the boards, de-solder it, and enjoy that warm feeling you get from not only recycling, but also saving yourself 3 cents (or more if you find some neat tropical fish caps, old carbon resistors, germanium transistors, etc.).
Yay!
-Joe Hart
Cursor
Quote from: Joe Hart on November 23, 2008, 02:05:52 PM
+1. I recycle resistors, transistors, diodes, caps, ICs (up to 8 pin at least) and generally 50% of a given project is made from recycled bits.
Just to be on-topic I'll add a somewhat worthwhile (although overpriced) Craplins offering -- the GCSE component pack @ £21.99 actually contains a useful general selection of bits and you could certainly make a fuzz or overdrive pedal from one. Includes a bit of stripboard. Edit: Meh, they're out of stock, and I wouldn't want to actually promote Maplins anyway.
timmyo
Cheers guys.
For my first order I kept it simple and just got the bits I need to mod my first pedal (a wah) – and I'm making up a list of other stuff to get me started with some building projects. When I think I've got that finalized I'll post it here.
Yes even I can tell that Maplin is not great (and certainly not great prices)
I've been looking on Rapid and BitsBox websites.
Good idea re the scavenging :D
Zben3129
For the beginning modder I actually wouldn't reccomend scrapping parts. You can still look for things and scrap parts out of them (very fun, never know what you might find) but I wouldn't use them in anything for a while. When you are starting off its necesary to not have to worry if the part you grabbed really is what it says it is, or if its a burnt component, or have to worry about the short leads, etc.
But having a stockpile of junk to harvest from is never a bad idea for down the road.
Zach
Cursor
The other bonus to the scavenging is you'll learn to read resistor and capacitor codes quickly :D
timmyo
ok I'm back tackling my shopping list (why does one place not have everything ?  ;D )
Zener diodes : what voltages do I need for general pedal use ?
grathan
I tried to get Everything on my first order. I spent over $500 and I realized only a week later that almost every interesting schematic I came across had a unique part that I didn't have.
a few kits from Small bear cover a lot of ground though.
http://www.smallbearelec.com/Detail.bok?no=170
http://www.smallbearelec.com/Detail.bok?no=192
http://www.smallbearelec.com/Detail.bok?no=638
http://www.smallbearelec.com/Detail.bok?no=639
http://www.smallbearelec.com/Detail.bok?no=640
http://www.smallbearelec.com/Detail.bok?no=641
timmyo
I'm trying to fo it from UK suppliers, but thanks for those links.
Right well I've placed an order with Rapid Online - came to about £80 (although that did include an enclosure and some other bits and bobs too.
