memory lane tap tempo
Started by ninjadave7, December 03, 2008, 11:02:47 AM
ninjadave7
how does the memory lane 2 use a tap tempo on an analog delay?  is it all still analog?
david L
iaresee
Quote from: ninjadave7 on December 03, 2008, 11:02:47 AM
I don't know but I can guess: it uses a small logic circuit to detect the tap rate, convert the rate to a resistance value and set the value on a digital potentiometer.
Quoteis it all still analog?
Yes. At least: the audio signal path is analog. They are likely using digital control logic.
ninjadave7
so it's not necessarily a very easy thing to do yourself.
david L
iaresee
Quote from: ninjadave7 on December 03, 2008, 11:59:46 AM
Easy is relative. :)
