Multiple Voltage Power Supply
Started by michael_krell, December 28, 2008, 04:39:59 PM
michael_krell
Does anyone know if theres a project that exists for making a pedal power supply that has multiple supply voltages?
Like 9VDC, 9VAC, 18VDC ????? Just so happens the 3 pedals i have on my pedal board use these voltages.
Any ideas?
Boogdish
michael_krell
I purchased a pedaltrain pedal board and I am trying to figure out a neat way to power everything. Those voodoo lab power supplies are nice and can attach nicely to the bottom of the board, but they are so expensive and I dont think they even have the voltage supplies i am looking for.
I almost want to modify the pedal so i can just supply them with 9VDC and 18VDC. That should actually be pretty easy to do with the Line 6 DL4.
George Giblet
#3
http://www.diystompboxes.com/smfforum/index.php?topic=60191.msg471144#msg471144
Don't combine AC and DC power supplies unless you use separate transformer taps to do so - you can end up will all sorts of hum loops and shorts.
