tremulus symmetry
Started by 1878, February 08, 2009, 06:01:01 PM
Hello Everyone.
Can you install a Symmetry pot on the Tremulus Lune without installing the fine pot ?? To be honest, I've haven't found the Fine control to be of much use, and I'd like to remove it.
This is the diagram I used to wire everything up...
http://commonsound.org/tremulus/symmetry.pdf
If I remove the Fine pot, would Lug 2 of the Symmetry pot go straight to the board, and Lug 3 of the Speed pot go to Ground ??
Thanks in advance.
GREEN FUZ
To answer the first part of your question, yes it can be done. It`s exactly what I`ve done. If I remember correctly I just followed Slacker`s direction in this post.
http://www.diystompboxes.com/smfforum/index.php?topic=65107.0
cloudscapes
the fine pot only uses two lugs. with mine I just wired it as if that imaginary pot was all the way to short the two. works like a charm!
{DIY blog}
{www.dronecloud.org}
blanik
i love the tremulus, it ended up being waaay above my expectations, i didn't put the fine on mine either, a good 100k reverse log will be easy to set, the spacing pot could also be replaced by a trim, for the symmetry pot you could use a mini switch (on-off-on ) instead of the pot...
