simulating modulation fx´s with LTspice..AC analysis variable with time?
Started by dschwartz, June 22, 2009, 02:34:32 PM
dschwartz
Hi there, i´ve been chewing the idea of designing a phaser (or any other modulation fx).
Since i´m really not a big fan of using the breadboard before simulating a circuit, i´m stuck on thinking how i´ll be able to visualize the changes on frequency response against LPF voltage changing over time.
Maybe i can simulate the LPF output with a DC voltage and make different simulations for different voltages to get an idea of how the filters respond to different input voltages. But i´d like to hear your experience on this, if you have better ideas.
Also, i´d like to use the 4049 variable resistor trick. has anyone simulated that on LTspice?
regards
Tubes are overrated!!
http://www.simplifieramp.com
