simple 2 inputs 1 output AB box
Started by mitzrecords, February 01, 2009, 06:35:01 PM
mitzrecords
hi, sorry this is often asked question here probablly. i searched but i came across with lots of looper or ABC box etc.
I just want to build simple AB selector. I just use 2 guitars and one amp so all I need is 2 inputs and 1 output. led would be good but necessary.
does anyone have diagram or layout?
thanx always!!! :icon_redface:
mitzrecords
sevenisthenumber
that is the same thing. just use the one input as the ouput and the two outputs as the inputs....
mitzrecords
 :icon_redface: :icon_redface: :icon_redface: :icon_redface: :icon_redface: :icon_redface:
ooops so i can just make that one.
thanx
sevenisthenumber
#5
the fulltone is a more intense a/b for fixing grounding problems associated with switching effects on the same amp. For a basic a/b its a little over kill.
fulltones is just this:
Eric Johnson's A/B
http://happybob.com/marc/circuits/AB/A-B_BoxWLED.gif
a basic a/b like you want can be wired like this on a DPDT footswitch:
top left pole = in #1
middle left pole = output
bottom left pole = in #2
top right pole = (-) of led for in #1
middle right = to ground
bottom right pole = (-) of led for in #2
All grounds of jacks, middle left lug (led ground) and power connect together.
(+) of leds go to (+) 9v battery or supply. [make sure and put a dropdown resistor say 3k between the led's (+) and (+) battery or supply.
